Hello Everybody, I have recently purchased this Omega 260 caliber. I got it for quite a bargain for this rare caliber, but i still believe the dial is a redial (not a very good one, too). I am looking for a replacement dial but it seems almost impossible to find a 260 caliber dial. Does anyone know if the 265 dial would fit this mechanism? Thanks for your thoughts, Alex
Ranfft seems to suggest that all the 30mm derived sub second movement are pretty much the same in that respect so I would say yes but maybe get a second opinion! http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&a&2uswk&Omega_260&
In your search for a dial, you will need to consider a dial that will fit the movement, but also the diameter of dial that will fit that case. The watch looks to me like a jumbo which is about 38 mm in diameter. That movement was used in smaller diameter watches with smaller diameter dials, as well.
I just checked, the 2271 is indeed larger than the normal 33mm 30/260 case but only a little at about 35mm so is a kind of mini jumbo!
