Omega 1506 flat link bracelet with 16 ends stamped 1/65
TFA SOLD
2000
Nice 1506 bracelet stamped 1-65 with the number 16 ends to complete your vintage Seamaster 300 or Speedmaster.
The 1506 as well as the 16 ends was manufactured in a very short period compared to the much more common 1039/516 combo. The bracelet came originally on a 165.024 produced 1964 which is now sold.
Bracelet is missing some spring links from the full link but have all 8+8 firms links, there are now 3+2 spring links. Making it total around 15,5cm without the flex. When it was mounted on the 165.024 I had one more adjustment hole left on my 17.5cm wrist so a 18cm wrist will be no problem + some room in the flexed links. Spring links can be scouted from the 1039 also if needed.
Springs are nice and tight and there are not much flex or wear in the firm links.
Ends are a tad under 20mm wide as well as the last firm links making it the correct width.
Price: 2000EUR net to me by bankwire or wise. I’m located in Sweden.
https://omegaforums.net/search/13022209/?q=hejsam&o=date&c[title_only]=1&c[node]=10
Mounted:
