Omega 1035 Bracelet with 630 Endlinks 18mm - 4+6 Flex - 17cm+ Length - All Original!
Price: $975 Including Shipping + Paypal Fees - Declared as $45 for low customs
Year: 71/4
Condition is just incredible, it's almost 18cm and pin to pin length is higher than 17cm, there are 4+6 flex links, the final links are 18mm, the endlink is like 17.96mm as it should be, there might be slight measurement errors
Basically apart from regular wear surface scratches, it's a perfect bracelet without any issues, I also cycled it in an ultrasonic cleaner a couple of times until the water was clear, so it should be ready to wear too
Flex links are tight and flex well, that's why the bracelet looks a bit wonky in photos, on a wrist it becomes flat with tension, the gap on one end will disappear into the buckle when you use the micro adjustments and set it inside, so it's a regular part of the bracelet
Endlinks are pretty much 100% - the bracelet is unpolished and from the endlinks, you can easily tell the different original brushing between the middle and the edges
