First off
@Foo2rama is right SP donates increased case water resistance, not the strap type.
However, your dial with the narrow Ts is incorrect for a 145. These were phased out in 65 or early 66, so the last of the 105s had the wide T dial.
Then you have a chrono hand from 68 or later.
You say the serials correct for a 145.012. Is that just a guess or do you have an extract as it's also correct for an early 105.012 when the narrow T may still have been used.
If you don't already have it, you need an extract here. Best case scenario, you have a 105.012-66 which went back to omega for a service at some point where they put the more modern pushers on and stamped this upgrade in the back with anew ref no. I think this is the most likely answer.
Worst case, you have a complete Franken.
