New Arrival, SM300 14755-61 With Original Bakelite Bezel Intact ??, Macro Shots Will Decide
Absolutely awesome specimen! It's definitely one of the best I've seen. I wouldn't take poison on that the bezel is original, but if someone could proove it isn't, I have learnt something new!
How long the glow lasts in the dark?
Lume pics are with a UV light. Lume pigments are burnt out by the radium and no longer glow independently which is normal.
Congrats on such a great find! Great piece! Watch out for those turnstile. 😜
No, if it's burned out, it would no longer glow at all, no matter what kind of light you use, UV or not. And it would usually look burned (dark/black) like your 2913 (which still has the lume material on the dial).
How is the reading from your Geiger counter?
PS: I have a hunch that it has tritium lume here. Let's see if the Geiger counter agrees. 😀
GC is Very strong, 3300 cpm. Truthfully, I haven't see the lume in complete darkness yet. Will look later. Perhaps there is some glow after energized by the UV light. I do have another 14755-61 with a "special ops" all black lume burnt dial as well. See below.
I'll try and compare GC readings and lume shots and post soon.
If the bezel isn't real, someone has come up with the secret sauce. All of the reproduction bezels I have seen all have tell tale signs not seen in Gemini's bezel.
Stunning SM 300 Marc ,I would love to get my hands on your crystal ball.
I searched in vain for the "Mind Blown" emoji. Wow.
@gemini4 Sorry to bump this thread ...just curious about the UV light pics ... as we know , Bakelite bezel should ´glow’ Green under UV ... but it might depend of the UV wavelength... your doesn’t seems to glow .. any idea of the wavelength your are using ?
Just some pics of mine to compare ...
Hi Fost, I think your bezel numbers are fine.
On the original 2913, 14755, 165014 bezels, only the piper dot, if intact, should light up. The numbers do not. They aren't radiant
The numbers do light up on the next generation bezel, for the 16x.024. Hope that helps.
I was not referring to the numbers but the black material which becomes green under uv
Ok sorry. I have no idea what wavelength my UV light is.
Honestly, I've never even noticed (or known) that the black background can turn to a color.
ok let get a bit deeper into it
you say bakelite is say no it isn't
on straight lug seamaster the material of choice was nitro celluloid which is way more sensitive to damage or environmental influences.
you see on the pic above that the bezel isn't luming on "scratched " parts, this comes due a cover sealing laquer and this is the part that reflects blackligh in a green color and not the celluloid itself.
Thanks for the information , very interesting!
