@palkastu no worries. Even “experts” should always double check when it comes to vintage.
So checking the case I think you’re good to go. Here are two side by side shots with a known example and it’s pretty kosher.
A couple of my other opinions:
Non-original Crown: as others have stated, a doxa signed crown would be best, but these do get replaced and I generally find it not a big deal in the big scheme of things. Unless you’re going for mueseum quality I personally wouldn’t ding the price too much considering the condition of the dial/hands.
Case: pretty rough, but I’ve seen worse and it’s certainly possible to laser weld and recut something if you want to spend the money on it. Otherwise, wear it as you see fit.
Dial/Handset: one of the better ones I’ve seen out there. And I’ve seen a lot.
Bracelet: this bracelet will be useless to you to wear unless you fix the extender springs. There’s a great guide on how to do this by cannibalizing an expandeo bracelet for the springs. Add in $50-70, about an hour, and nerves of steel to get this bracelet up and running.
Regarding price, I’ll let you DM me if you want my humble opinion. I’ve seen a lot of data points but they are quite volatile, and if you decide to pass the please do keep me in mind.
And if you decide to buy the watch then I’m calling dibs right here. Right now.
