Hello all! First of all thanks for reading my post! I'm looking for a crown for an Omega Automatic, gold tone case: LL6304. I ordered one from jules borel, however I don't believe it to be correct. I will attach photos of the crown they sent me, as well as the case and caseback of the watch in question. Thanks everyone!
That is most likely the modern Omega replacement that would fit the case. There are many cases (especially these USA cases) for which original crowns are no longer made. This is one of them. gatorcpa
Thank you for the response! Should I go ahead and use that crown then? I won't be able to return it once I do. Thank you for help, its greatly appreciated.
Do you like the way it looks with the watch? Your watchmaker should be able to measure the tap size on your crown an compare it to the specifications of this one to see if it fits properly. gatorcpa
The problem is that if I open that plastic package I can't return it to Jules Borel. So I can't compare them
http://cgi.julesborel.com/cgi-bin/matcgi2?ref=\]ZETEXM]q This seems to be the correct crown, If Im not mistaken?
There are two crowns listed for both white and yellow. Not sure why. http://cgi.julesborel.com/cgi-bin/matcgi2?ref=OME_CS^6304 gatorcpa
Strange.. I'm assuming the ones they sent me is for the split stem devilles maybe? they sent a female end with it.
How much did you pay for the watch? I'm interested in one that has the same model reference of yours. But he ask 1100€. A dealer of omega told me that it's overly polished so it lost most of it's value.
