Watch appears to be in very good condition, but what you ask for can not be readily assessed from the pictures alone. All the information needed for that is on the inside of the case back and the movement itself. Obviously it is an Omega Deville. Bracelet is plated as you know. The movement serial number will date the watch and the case reference numbers on the inside of the case back will pin point the exact model, which should correspond to what is seen on the outside of the watch.
