Hi all ! Need help to extract stem for replacing battery. Hope that removing the dial isn't the only solution
grab stem with a tweezers and unscrew a crown p.s. sorry just saw that maybe this will not be possiable here becouse of waterproof "neck"...or is that crown? Cant see good.
Is it a stem in two parts? Normally with this type of cases, you can put your tweezers between crown and case and the crown will come off.
Thank you very much ! It is a screw crown and the watch is old so it's really fixed... i can't,i will go to a watchmaker. Thank you all ! You are the best
