https://www.omegawatches.com/watch-...moonphase-chronograph-44-25-mm-31130443201001 Try contacting your local Omega Boutique - these are not sold out...
Welcome back. If the model is no longer available to order from Omega, an AD will not be able to get one for you. Did you try an Omega Boutique (as suggested two weeks ago)? - They are able to move things within group stock, and will collectively be holding any of these that are unsold. Did you ask @Kringkily (as suggested two weeks ago)? He has found lots of watches, for lots of members, and is a stand up guy.
Thanks for the response and advise. I have reached out to @Kringkily, pending a reply there. No luck at the OB.
I just realized the difference OB /AD - I will check OB location today. Tourneau has been borderline useless.
No luck with Kringkily, no luck at ANY OB, or AD. Please keep me in mind for: 311.30.44.32.01.001 Thank you OF
It’s the large 44.25mm 861 based moon phase. Not exactly a huge seller or available for that long. Looks like a hunt is on. The 42mm variant is easy to source.
