OMEGA, Seamaster, Mariner III, approx 80'S. You must check movement, there are fakes out there. Bracelet has the correct ref: #s that's a good start. Hope you find it's legit and movement image & #s will verify.
Correct watch:: below. Cal 1430 Case 396 Quartz 6 jewel (a couple hundred bucks) Sentimentality is the value!
Suggest you keep it and wear it well.
