That is the 41mm case, yes. Model 2531.50, from later than 1997 as it has Superluminova lume. As noted above, that looks a bit well worn but a full service would bring it up as new, the case condition suggests that the movement probably needs servicing too. Ask for a close up pic of the back of the lugs, there should be a tiny 8 digit number lasered on there, if you post the first couple of digits we can give you an idea of year, if it is missing it may mean that it is a grey market watch which lowers the value a little and is a turn off to many buyers.
