- Posts
- 11
- Likes
- 19
Chagão
·Hi, My strap came loose and dropped my Polerouter.
Since then I had issues with the minutes hand.
Any sudden movement ( a shake of the wrist for instance) can send the minute hand either forward or backwards by up to 20 minutes.
When the crown is pulled to adjust the time, depending on the position of the watch ( face down), sometimes the minute hand moves but the hour hand does not follow. Also with the crown pulled, the minute hand moves in sync with the seconds hand, not very common but happened at least 3 times .
Took to a local jeweler (omega, IWC etc dealer) and they want to do a full rebuild which costs a fortune and will take between 2 and 3 months.
The crystal popped out, when it fell, but I was able to press it back in, at that point I did not notice any issues with the watch.
Any ideas as to what might be happening here? And what kind of repair is needed?
MICROROTOR 218-2
Thank you.
MICROROTOR 218-2
Thank you.
