Mechanical Watch Manufacturing Questions
In manufacturing, dimensions are free, but tolerances cost money.
I've never heard this before, and I love it. Makes perfect sense for watch movements and the precision scientific instrumentation that I'm familiar with. The "dimensions are free" part may not be totally true for precious metal cases. 😉
Try grinding plano optical flats @ within tens nanometers [ Bilionths of a Meter ]
Ground & polished optics @ Huges Research Labs for a brief time.
Other wise known as Newton rings or color, the air space rings between flatsurfaces.
It has been noted the people that grind & polish the super large telescopes wind up commiting Autocide before or after the mirror suface is completed.
If not for watchmaking modern electronics would not have happened.
The growing of bules for the silicon wafers = same process for synthtic jewels.
The company that makes Hairsprings in CH makes the heating elements in aicraft windows. Can you find them sandwiched in there somewhere?
Contest years ago, who can ( Country ) can make the smallest drill bit.
CH sent one from the USA back with a hole drill through it.
Wow, I would think just the natural vibrations all around would not allow flatness to be ground down to that many decimal places. Must be lots of proprietary technology around that process.
I'd want to get a look at that drill bit with the hole drilled through it - sounds a little like Robin Hood splitting the arrow already in the bulls-eye. There are other ways to make small holes than drilling.
I briefly worked for a tool-making division of Kyocera and we were making 0.050mm diameter drills. I'm confident we could have made them smaller, but that was the smallest in our catalog. The coolest tiny cutting tool we made was a 0.080mm diameter 4-fluted ball endmill.
Hughes research lab had some nice lasers too.
I ground & pollished this recangular block of Non-Oxidising copper, it had a very very small hole in the center. To keep the desired piece true there were blocks arround it so the edges would not round. They use ruby red lasers to align the chemical lasers.
On another note for those interested in early quartz watches, Huges made some but not sure how many. I am sure they are RED LED displays though.
I haven't checked ebay to see if any have shown up.
I saw one the other day. Probably still there.
You mean like this?
So I had a look through some photos, and I thought I might have something that isn't a marketing video, or hearsay/guesses, but actual drawings with dimensions and tolerances...here is what I knew in the back of my mind I had somewhere in my archives...
This is a photo I took of a manufacturing drawing for the main plate of a watch movement. Here is a closer view where you can see some tolerances for some of the hole diameters:
So the tolerances you see on some hole diameters there are 0 to +4, -2 to +2, some are looser so -2 to +5, and even a few at -2 to +7. These would be in 100ths of a mm.
I've not yet come up with anything for tolerances on things like pivot diameters, but I'll keep looking.
One thing to keep in mind with tolerances is that in a production situation, there are different types of tolerances. In a situation where you are making a one off part, the only tolerance that is important is the final tolerance to determine if the part is good or not.
In a production process that is continuous, meaning that you are machining one part after another for an extended period of time, there will be final tolerances, but also another complete set of tolerances - process control tolerances. These are tolerances that are tighter than the final tolerances, and in a situation where the machine tool is for example turning part after part, the operator would take samples at set intervals, check the critical dimensions, and plot the dimensional changes over time. This is often done via computerized systems with gauges that are connected to a computer and software that will plot subgroups of checks, and plot the process in graphical form. This allows the operator of the machine to view the process to follow the trends for things like cutting tool wear, and when for example an offset needs to be put into the controller to account for tool, wear, or when the tooling may need changing.
My engineering days were spent in the automotive world working for a tier 1 supplier, so this sort of thing was the norm for machining processes of any kind. I've been through a lot of watch factories, so Blancpain, VC, PP, AP, Chopard, JLC, as well as some independent shops.
Of all the factories I've been through, the only one where I saw quality assurance data posted up on bulletin boards in the same manner I would expect to see in an automotive plant, was at Patek. They were a little sensitive (to say the least) about me taking photos at all, and I had to ask permission for each one I took, and those charts were off limits. However, looking at it and understanding the numbers, I was a bit shocked at the rate of defects - in an automotive world these processes would be seen as being out of control.
You mean like this?
Really cool - what was the set-up for this, and at what distance? I'm imagining something like the way they set-up the splitting a bullet with the blade on "Forged In Fire"
Did you tour the ETA machines, and see the assembly of Swatch Watches?
Completly assembly robotic & packaged without being touched by human hands!
The story of the drill bit has many variations.
Look up on Engineering 360, Extremely Thin Drill Bits True or Not?
I am a Cleveland escapee. Rumor came from Cleveland Twist Drills, as I heard it through the grape vines [ Sorta Speak ]. There were also a question if they used a LASER. To date, smallest hole 22 micons, .00086614" through EDM!
Anyhow, An Engineer ha, there the arogance that comes through.
Just winding the mainspring boss!
Glad to have your input.
I liked Jager tour, it was a whirlwind tour. As the gal giving the tour was heading for Paris when she finished the tour!
Did they still have the aircraft clocks throughout the production areas?
Did Rolex give you a tour, they had a vid on youtube of the new facility.
Wow, this is so cool that you can share this spec!
The format is a bit unfamiliar to me, but I'm going to study it for awhile. It's definitely not GD&T per ASME Y14.5 with the X and Y coordinates on the table, but it's not immediately obvious to me what the X' column is for, and I'm wondering if that column all the way on the right "R-[diameter]-S" is some sort way they're expressing true position tolerancing?
Based on the tolerances the holes are most likely reamed, but not honed.
Your observation regarding what would be acceptable for Statistical Process Control (SPC) limits in automotive compared to watchmaking actually doesn't surprise me. Nobody is going to die if a watch movement jams (except maybe James Bond?) I teach Tolerance Analysis in the medical device industry and one of the primary points I try to drive home for the young engineers is to always consider severity and detection in designing for manufacturability. An undesirable fit in an assembly, if undetected (and 100% inspection is NOT an effective detection method!), will result in some consequence that may be insignificant, or it may potentially result in patient harm.
So it appears that the X' column is just all of the respective additive inverse values from the X column. I assume there's some point in the machining process where the workpiece is flipped-over along the Y-Axis and features are cut into the opposite side? Or some features are inspected orienting it upside-down (rotated along the Y-Axis) from this view maybe?
All things considered, precision machining tolerance also have other considerations.
Materials used, expansion, contraction, galvanic reaction to other materials....
It has been said, ( Don't know the source] One problem WWll Germany had were the tollerance were to tight. They worked great in the lab, but failed in the field.
American troops had a problem with rifels during Nam Advisory state, [ Never declaired a war! ] one soldier's rifel jamed & grabed his bow & arrow during a conflict.
He retrived most of the arrows, but a few were never accounted for, prety sure target hit.
So, gold plates, nickel, brass,....
One of the students questioned a trainer consultant from a big mfg about tighter production standards. His response, yes it is possible but the failure returns are too great, as humans feel & touch could not be replicated in a mass assembly production.
I think they prefer “sales rep” to “salesman”, but yeah it’s a great industry to make your career in whether in engineering or sales. I was in the Army Reserves for 22 years so no desire to get reacquainted with the DOD. Where I work now I design catheter delivery systems to place stents and valves into the heart. Instead of open-heart surgery I give the docs a tool that they can run up the plumbing starting at a 3/8 inch incision in the inner thigh. Patients are typically back home next day. My current project is for treating pediatric congenital heart defects, so this is the most rewarding work I’ve ever done - it really feels like a privilege sometimes to get to work on solving these technical problems.
You might be familiar then with Dr. Gundry's research.
A buddy works for Medtronics in R & D.
Self taught electronics whiz, name on a few patents with them.
When he started, wound up teaching the folks with sheep skins how to design ac to dc filters. For a clean dc voltage supply.
Shot with my Olympic recurve set-up at 18m, which is the regulation indoor distance. Same set-up you see here (but this is at 90m):
We actually try to avoid this, because it's costly ($$), and because the arrow that hits the arrow that's already in the target will deflect out of the middle and cost you points.
So in tournaments we shoot 3 arrows per end, and then go to score and collect them. We use "3-spot" target faces, meaning that each target has 3 smaller targets printed on them, and you shoot 1 arrow in each of the 3 targets to avoid this sort of thing happening. This one was shot in practice when I was shooting multiple arrows at one target.
Sounds great!
My wi-fi won't let me see the vid though.
Buddy in CO, his sister went to the Olympics with archery, late 1980 or so.
His father would take Governer's cup home in shoots, worked Rockymountin Arsnel security.
Did you get a tour through mainspring and hairspring production.
Mainspring tour had a funny thing happen.
One of the Finish guys wanted to see the process for spot welding the bridel.
When he approached this gal's station, she protested.
Put the work down, crossed her arms & said No!
Everyone looked asked, "What did you say?" He said, "Nothing!" He blushed & was caught off gaurd. They would not say what inert gas was used in the ovens to set the springs. We wound up in a control room & I looked at the panel.
Nudged JJ a classmate & said, " Bet it is [ recalling from 1995 is hazey ] think its krypton?" Pointed out he gauge on the panel. Yep, probablely so.
Maybe, The watchmaking school in Oaklahoma has an on line library that you can tap into for the mfg tolerances.
They were going to close the class down 2018, but Rolex donated $1 million to keep it going in 2019 for 5 yrs.
There also is or was a school in PA that was backed by the Swiss, Rolex that taught all the machining & tooling for production of watches.
Heard students went through the course expecting employment, but just like the
W.C. Field's movie, "The Bank Dick!" They got a calander & a hardy handshake.
In the movie the bank pres. Hardy hand shake, he holds out 2 fingers & it is highlited.
Nope, don't know that doc. I'm a mechanical engineer, ...but I did lead one electro-mechanical design project several years ago at a previous employer and got a couple of patents issued on that design. I did all of the mechanical design and manufacturing engineering, and I had 2 EEs on my team to handle the electrical design work; one software and one hardware. That was in the orthopedics space.
Help me understand, I have no experience in archery, that picture you shared of where the one arrow split the other - that was something that just happened whiteout intent? I assumed there was some pre-designed, installed, and validated set-up with the goal of doing that. How frequently does that happen even with the process safeguards you mentioned that they put in place for competitions?
No, as I said we try to avoid this. Obviously if you are only shooting one arrow at each small mini-target, you won't ever hit another arrow, so this is something that only happens when you are shooting more than one arrow at the same spot.
So at 18m in competition, it never happens. How often it happens is in practice directly proportional to how good you are. 😀
I'm sure many have shot for years and years and never done it - I've done it at least half a dozen times from what I recall. And yes, we do call it a Robin Hood.
Outdoors in the old round we used to shoot, we shot arrows at 4 different distances. 90, 70, 50, and 30 m. There are typically 4 archers on a target, and at 90 and 70 you shoot 6 arrows before going to score and collect them. So there are 24 arrows trying to hit the same spot on the target at any one time. But since the distance is long, the chances are less this will happen. At 50, the target is smaller and you shoot 3 arrows before going to collect them, so closer, but fewer arrows - chances are slightly more than at 70 and 90 in my experience. At 30 m, again you shoot 3 arrows each, and like indoors there are separate mini-targets. But instead of one for each arrow, there's one for each archer. So at 30 m, the number of arrows per target is less, but you are close enough that it has more chance of happening (to your own arrow) than at the other 3 distances.
Having said all that I was at the US National Championships one year, probably around 1999 or 2000, and on my target someone shot a Robin Hood on another arrow. But that arrow was in 5 ring, so no where near the center...and no it wasn't may arrow that was hit or me that hit it. 😉
