Lift Angles for New Coaxial Calibres
All of the 8XXX movements, with the exception of 8806 and 8807, are 38 degrees. The 8806 and 8807 are 36 degrees.
Note that unless you have a timing machine that has additional programs that are made specifically for measuring co-axial movements, the amplitude readings will not be reliable even if the lift angle is set to the correct number. Many cheap machines are sold as being able to "measure co-axial watches" and they can for the rate, but not for the amplitude.
