Lift angle setting for cal. 8500
  1. sailingchamp Jan 19, 2016
    I have bought a timegrapher to check my watches and wonder if Archer or other competent people know what figure to set on the timegrapher when testing a cal. 8500 (default is 52°)? With the default setting the amplitude reds at 6 positions with watch 1 (see signature) between 320 and 345 degrees, with the Master Co-Axial 8500 watch 1 between 300 and 310 degrees and with Master Co-Axial watch 2 between 315 and 345 degrees.
    In another thread I've read that for a Planet Ocean the lift is 38°, but this was a 2500 co-axial movement and not an 8500 as in my ATs. Can I use a value of 38 degrees for 8500 movements?
    All measurements fully wound-up movements.
    Edited Jan 19, 2016
  2. oddboy Zero to Grail+2998 In Six Months Jan 19, 2016
    Hey Champ,
    What signature? Which watches?
  3. sailingchamp Jan 19, 2016
    Omega Aqua Terra bicolor you see left of the text. Sorry for the wrong word, I'm a foreigner.
    oddboy likes this.
  4. oddboy Zero to Grail+2998 In Six Months Jan 19, 2016
    Ah, the pic! Commonly referred to as Avatar around here.
    I'm sure someone more technical than me will be along in a bit.
    sailingchamp likes this.
  5. wsfarrell Jan 19, 2016
    This says 38 degrees.
    link
  6. sailingchamp Jan 20, 2016
    Many thanks.
  7. Northernman Lemaniac Jan 20, 2016
    Just to make sure.... Does your Timegrapher support coaxial movements at all?
    Coaxial movements have a different escapement, and hence a regular Timegrapher (such as my own) would not report correct figures.
  8. sailingchamp Jan 20, 2016
    Yes it does.
    Northernman likes this.
  9. Northernman Lemaniac Jan 20, 2016
    Cool, must have updated firmware compared to mine. What is the model designation on it?
  10. sailingchamp Jan 20, 2016
    It's a cheap chinese Weishi (ha, ha) 1900 bought on ebay for ca. 310 $ including postage.
  11. Northernman Lemaniac Jan 20, 2016
    They are great help. As long as you do not go staring yourself blind on the figures. It is easy getting a bit lost when one does not have full watchmaker training. Member Archer wrote some very good comments on this in a thread some time back.
    I have the older model 1000. Same maker.
  12. Archer Omega Qualified Watchmaker Jan 20, 2016
    As noted the lift angle is 38 degrees, but I very much doubt the machine has a special program to properly analyze co-axial escapements.
    The other readings for timing and beat error will be correct, but the amplitude numbers won't be.
  13. sailingchamp Jan 20, 2016
    Thanks Al, of course it's a cheap device and in their advertising the company said it's for co-axial movements as well. OK, if the readings are correct except amplitude then I'm not too concerned.
    The daily error for my 3 watches are (dial up/dial down/crown up/crown down/12 up/12 down):
    AT bicolor: 0,6/2,2/-1,2/-1,4/-3/1,2. On the wrist for 16 hours and dial up for 8 hours: - 1 sec/day.
    AT Master blue dial: 6,7/4,9/7,0/4,6/5,4/5,4. On the wrist for 16 hours and dial up for 8 hours: +3 sec/day.
    AT Master Ryders Cup: 6,4/8,7/9,0/4,3/6,0/7,8. On the wrist for 16 hours and dial up for 8 hours: +5 sec/day.
  14. Archer Omega Qualified Watchmaker Jan 20, 2016
    Of course they all say they can be used for co-axial, because aside from amplitude they can. That doesn't mean that they have the special programming needed to analyze amplitude - you would have to change a setting to a different program on the unit if that were the case...
    Thrasher36 and sailingchamp like this.
  15. sailingchamp Jan 20, 2016
    Thans again, Al! I understand your point.
  16. GoDeepBlack! Mar 26, 2017
    I just bought an Ace Timer Time Grapher myself and was wondering two things. 1) Lift angle for the Deep Black? 2) What is the USB port in back for? (First post from me, by the way.)
