A great looking Lemania SC!
Beware that Lemania did references based on case design alone. Otherwise modularity seems to have been key. Due to this, looking at dial/hands and sometimes even movement ref can not be judged correct or not.
Case ref 920 and 941 will be correct for SC cases.
I own a SC with the same dial as the one listed.
Unfortunately it has been damaged by moisture and is residing in the parts boxes.
The signed Lemania SC crown is very desirable. Otherwise the watch appears to be in great cosmetic condition.
The cal 3000 is generally bulletproof.
If the price is not silly I would definitely recommend a bid.
I can not say if it’s early or not.
