Yes it’s legit. Even the crown is correct. Just make sure the lugs haven’t been resoldered - i can’t tell if it’s dirt/shadow or soldering marks on the photos.
I can't see it. If I purchased it it will be online
For the lugs I thint is only dirt.
What do you think about the price ?
Is it worth it ?
Thank you for your reply 😊
The price is good if the lugs are intact IMO
Price seems about right, as long as you're ok with the condition and prepared to pay for a service.
The condition is no so bad, isn't it?
It is ry and need a service but the gold plated seems to be OK. The dial seems to be clean small patina.
For the price it seems to be acceptable ?
It may well just be dirt, it probably is. But I believe the gold capped versions of this watch had the lugs soldered onto the case rather than being one piece. As a result, the lugs are prone to snapping off.
It just concerns me that there are significant dark areas around the lugs but not so much dirt in the various recesses of the caseback.
