JB Champion Bracelet End Links Help
  1. Mapearso Dec 19, 2017
    I have what I believe to be a correct 19mm JB Champion bracelet for my Evil Nina
    The bracelet has endlinks marked "76". They do not fit the Nina well at all. They are not as long / tall as the correct UG endlinks and as a result there is a big gap between the endlinks and the case. The width of the endlinks and the fit between the lugs is fine
    Does anyone else have this same bracelet / endlinks combination on a Nina?
    Can anyone suggest if there are better endlinks that will work?
    Any advice / suggestions would be appreciated! Thanks and Happy Holidays!!
    (Photos attached. Note these photos are not mine but are exactly same end links and bracelet..)
  2. ucsbgsmith Jan 14, 2018
    Hello,
    The endlinks on my similar UG Champion bracelet are marked "55."
  3. Lucas Jan 15, 2018
    I believe this bracelet was intended for unison models.
  4. Diabolik Jan 15, 2018
    76 should be 20mm. Some have been ground to fit 19mm lugs. The end links by champion do not fit compax, tri compax or space compax cases. They are a sloppy and move around. Best end links are GF. They are the correct ones. See article about bracelets and end links for info.
  5. Mapearso Jan 16, 2018
    Thanks Diabolik.
    I have looked at the GF endlinks thread here. Unfortunately, and as you probably know, sourcing a GF bracelet with correct endlinks is difficult and very pricey.
    Sourcing just the GF endlinks is also very difficult, and while the correct GF endlinks will fit the case properly, I am not sure they will attach properly to the JB Champion bracelet!!
    I am still hoping there is a solution for the JB Champion bracelet I have which is quite nice. Not easy, this UG stuff ...
  6. Chron Jan 18, 2018
    I got one with mark "55" that comes with my Polerouter Sub later exec. fits perfect on the 20mm lugs.
    3cc37fdd-abd3-438d-a67e-28f099290e10.jpg 9a4dc883-c58e-48fa-8642-2d8b563f2594.jpg 3560147a-4b00-4a2f-a5e0-06dc7d6f6303.jpg
    Mapearso and Billi like this.
  7. Mapearso Jan 18, 2018
    Thanks for the info...
    So now I am wondering... If as Diabolik says JB Champion end links don't fit Compax or Tri Compax, then which UG model was the 19mm JB Champion bracelet made for???
  8. Mapearso Feb 8, 2018
    Space Compax with JB Champion with "55" end links -- Fits "OK", but not as well as ones I have seen with GF
    55 JB Champion End Links.jpg SC barn11.jpg SC barn 9.jpg SC barn1.jpg ug sc mk1 is8.jpg
    Anyone have more info or photos of a Nina with a JB Champion bracelet?
    Thanks!!
  9. Diabolik Feb 8, 2018
    GF end links fit so much better than the champion equivalent ...
    DSCN0932.JPG DSCN0933.JPG DSCN0934.JPG DSCN0935.JPG DSCN0936.JPG DSCN0937.JPG
  10. Mapearso Feb 8, 2018
    Yes I know.
    *Very difficult and expensive to find GF bracelets
    *I don't think GF end links will fit on JB Champion bracelet? Can you advise?
  11. Diabolik Feb 8, 2018
    I have some jb end links. Unfortunately they are not interchangeable ...
  12. Mapearso Feb 8, 2018
    Thanks for the info. Some "55" JB endlinks would be very helpful :)
