The metal stamp is on the movement spacer, those are usually brass but I would suggest that if there are as I suspect hallmarks in the clasp then rest of the case minus glass, movement, dial and hards is likely 9k gold.
@BatDad I’ll buy similar from you at $200 all day long!
It’s worth scrap only but at over £11 per gram that scrap is valuable. I bet there is over 50g of gold in it. Maybe nearer 100g.
