Hello All....I recently found an Omega that belonged to my grandfather a few months ago in his drawer as we were cleaning up. This after almost 20 years after his demise.
The watch seems to be a manual winding watch and is in not a very good condition. Time can be kept when its wound but its about 2.5 - 3 minutes back from my stopwatch (Perhaps not too bad for a very old watch). Haven't really tested it to see how long it takes before it stops working. Rough estimate from the info that I received is the watch has to be at least 45-50 years old.Grandfather was wearing it in the 60's or so.
I sent the watch to Omega service center in Malaysia to get more details as I could not determine the model or anything of the watch. Omega in Malaysia could not determine this as well and recommended to send this watch to Switzerland for checks to determine what's wrong and what needs maintenance.
After about a month, this is what they found :-
1. The watch needs a full maintenance service
2. The lubrication is dry, which means that the watch’s function cannot be guaranteed
3. The movement shows signs of dampness having penetrated it
4. The dial is stained
5. The dial is oxidized
6. The hands are damaged
7. The dial could remain in its current condition
8. The case is corroded
9. The case is scratched/shows signs of wear and tear
10. The attachment fixing the bracelet to the case are worn
11. To ensure water resistant , the case must be replaced
12. The case back is scratched
13. The case back is corroded
14. The case back exchange is not necessary
15. The crystal is scratched
16. The bracelet is not of our manufacture and therefore no intervention will be carried out
17. The bracelet shows signs of wear and tear
The works which were to be included in the maintenance was :-
Complete dismantling of the movement, cleaning, oiling, reassembling, regulating and checking functions.
Repair or replacement of parts of movement that is worn or faulty.
Replacement of crystal, tube, crown, gasket and battery (including cost of spare part with the exception of special mineral glass or sapphire crystal and precious metal parts, which are billed separately.
Refreshing metal case and bracelets
Final technical and aesthetic check
And the cost for all this : Approximately RM 5600 ( USD 1750)
This was way out of my estimated cost and decided not to continue to get it repaired.I took it to a watch shop near my place in Klang, Malaysia and had the 'old experienced' guy have a look at it. He said something about a balance being damaged/broken and it cannot be fixed.
I'm still hoping to get it looked at again by someone else who can give me some advice on whether any 'reduced' cost maintenance can be done just to keep it running, and just improve the cosmetics of it. Not planning to wear it but just something to keep. And if I managed to get it fixed and keeping somewhat accurate time, to buy an Omega metal strap to replace the current one.
Even after all this, Omega still hasn't been able to tell me the model and the year of make. Would cost be another RM300 more for them to dig into the archives. So far this is all I got
Case Ref: ST25431
Type: Manuel/Handaufzug/Manual
Calibre : 231
Serial no:12317550
Bracelet: ST non OMEGA
Dial: Silvered
Any help I can get would be greatly appreciated.
