Hi All, Up for trade is an immaculate Electric blue dial Seamaster in stainless steel. Looking primarily for a circa 2007 Seamaster Bond wave dial or similar, but I am open to all possible trades . I have swapped the bezel insert with a brand new genuine Omega blue one. The original polished steel insert comes with the trade and is in perfect mint condition. This trade includes the watch, bracelet, blue nylon strap and instruction booklet plus all the parts which were replaced during its service last month. The watch comes with the service certificate, pressure test printout. Case size 42mm (full size) Stunning blue wave dial. Full movement service to Omega specs including new Omega mainspring. Only synthetic lubricants used. Timing and power reserve is now well within Omega factory specs. Full case service to Omega specs (new crown+tube, new HE Valve complete, crystal seal, case back seal. Bezel insert and click spring) Full case and bracelet refinish - sharp edges and correct types of finishes reapplied. All removable pins and tubes in the bracelet replaced with Omega parts. Proper pressure testing - Dry vacuum to -0.7 bar. Pressure to 10 bar. Wet test to the full 300m plus 10% safety margin. ALL parts replaced in the service will be shipped with the watch. The watch is approximately 18 years old. Bracelet will fit a 7 1/2 to 7 3/4 inch wrist Trade value circa USD 2,400 - 2,500 (will consider trade with cash to you or to me)
