- Posts
- 24
- Likes
- 8
bitt3n
·When I received the watch the light worked and the LCD did not. I cleaned off the heavily corroded battery contacts and now the LCD works, but only intermittently (turns off while wearing occasionally and turns on again if I nudge the battery). I suspect the problem is that the contact is in bad shape. I managed to break the contact for the light (the right one) rubbing off the corrosion with a cotton swab. I'm wondering what the easiest fix is for this.
