In order to have a watch keep time, it must be repaired (and that means everything necessary to return the watch as close to as new condition as possible), rated (that means it gives a stable rate under all conditions and over time). If it cannot be rated thusly, the repair is not complete! Only when the rate is stable (not necessarily keeping accurate time yet, but exhibiting a stable rate), can the watch be considered repaired, and only then can regulation begin! Repair, rate, then regulate! The regulator is NOT there for you to use to mask hidden problems! A watch that is sometimes out 20 seconds, and sometimes one second cannot be regulated! It's as simple as that! A watch of the quality of the subject Omega should respond well to professional treatment! As I said in an earlier post, my 60-year old Omega 355, recently thoroughly serviced, runs within one minute per week. And if I was to fuss with it, I could bring it closer than that. But I have only worn it for a week at a time, on rare occasions. The 60 year old unpedigreed bumper automatic presently on my wrist which I serviced last Saturday (Sept. 3) has varied 19 seconds since I put it on my wrist. I haven't fussed with this one, either! So many watches, sigh!
By the way, the subject watch has a TWO-PIECE regulator. So it is very much possible to have it keep time with the regulator in the middle, regardless of what you read elsewhere! But it must be repaired, rated, then regulated!
