Check to make sure the screw is the proper one - that one seems short to me. If it is not the right one it will let the pusher stem fall out, and then the operating lever won't stay in place or engaged properly with the pusher stem. If you have to get a new screw, a quick work around you could try is to install the enlargement ring - that might keep everything in place.
