So to add on what
@alam already stated, the 94521813 (polished) and 94521833 (brushed) clasps are the ones most associated with Speedmasters. The 94521613 16mm polished clasp originally came on the newer (post 2005) Speedy Pros from the factory with a 20mm (lug) 16mm (clasp) alligator strap. Later models (around 2010 I believe) came with the 94521813, and from about 2012 or so I think the 94521833 18mm was available. The 94521833 would usually be specified with the strap versions of the Seamaster and Planet Oceans as the brushed look better matched with the sportier watches.
From about 2014 or so the newer Omega clasps had a "Shield" style clasp end vs the "Rounded" clasp end. The part # is 94521883 and is tougher to find since they're a newer version. Some places say it's 19mm, that is incorrect it is 18mm. Here is a pic to show the design (not mine):
Any 18mm clasp should work with Omega straps, however you'd want one that's a single fold over style with push button side releases to have it fit in the same way as the original Omega clasp. The "replica" Omega clasps (the ones very similar in design) that are out there tend to be of very low quality and don't operate very well. The clasps that are fold over but don't completely mimic the Omega design (like Hamilton, Hirsch, FConstant, etc.) tend to work better but are a little bulkier.
