Can anyone help please. I've just purchased a new Speedmaster Coaxial 57, which is a great watch. However, the adjustments on the s/s metal bracelet don't offer me the fit I want. Either a little tight which at times is uncomfortable, or too loose so it moves around on my wrist. My other watch is a Brietling on a rubber strap with deployment clasp, which is so comfortable to wear, therefore I am now looking to buy an Omega rubber strap with deployment clasp. Can anyone please help with suggestions as to what model Omega strap will fit the new Coaxial 57. Very grateful for any tips / advice you can kindly offer
for sure the Omega OEM strap and deployant will fit and is a great combination! I'm sure @Archer can help with part no. information.
Hi mozzibite thanks for your reply. Can you please explain more re the micro clasp? Is it a genuine omega part? Will it fit with the bracelet?
There are several threads on here if you do a search. One here.. https://omegaforums.net/threads/adjustable-clasp-for-the-8500-po-42mm.64910/ I just got one for my Planet Ocean and it was a direct swap, but the Speedy bracelet might need different end links to fit the clasp. Don't know, but I'm sure someone else will advise.
Can anyone advise if the micro adjust clasp will fit the speedy? Think most omega agents don’t like swapping to one which isn’t supplied as intended. I would also like option of a rubber strap, very grateful if anyone can advise re part numbers and compatibility please? What size are the lugs on the speedy 57?
