Looking for some help, need to remove movement from case. Do I need to remove the bezel to take the movement out from the front?
Well, it's got a separate caseback so it's not a front loader. By way of deduction, it appears to me that you need to unscrew the screw with the bracket attaching the train bridge to the case. And also remove the stem. If you don't know these self-evident things I suggest you're not the person to be opening a watch case and you should take it to a watchmaker.
Remove the bezel/crystal and then remove the hands. Turn and remove the movement tabs and the stem/crown. Push the movement out from the back onto a clean movement pad. Edit: Just like you did earlier. (My fault for replying to dead duplicate posts).
