I am looking to replace the crown gasket of my 145.026 flightmaster. Does anyone know the right gasket for those crowns? Any help would be appreciated. Thanks, Tom
ok so i bought a lot of different size crown gaskets and found one that fit, i installed it and the crown feels tight in its tube now (before that it felt like the crown was loose inside the tube). I will be replacing a lot more of my crown gaskets going forward.
Can you share the gasket size for the flightmaster crown?
I used a 3.2mm gasket. I do not remember the width of the gasket i used though. I know i should have written it down but I tried so many that i forgot to check. I would assume i used the 1.8mm width.
