  1. jeppehh Feb 15, 2019
    Found this watch in an online forum. Dealer offers no movement pictures or much info, except that it is a 38mm.
    Some research suggests that this might be a cal 265.
    Can anybody tell if this is correct and whether it might be a redail?
  2. Temprus Feb 15, 2019
    Ref. 2505. The dial is ok, wrong crown.
    jeppehh likes this.
  3. OMEGuy Feb 15, 2019
    I'd say that this is a ref. 2505 and it looks legit to me. This is not a redial.
    Not 100% sure about the crown.
    Edited Feb 15, 2019
    jeppehh likes this.
  4. jeppehh Feb 15, 2019
  5. OMEGuy Feb 15, 2019
    DaveK and jeppehh like this.
  6. jeppehh Feb 15, 2019
    Yes. I'd say you're right. Also looks like Temprus was right about the crown.
  7. hungdangnguyen23 Feb 15, 2019
    does the case look soft to you guys?
  8. jeppehh Feb 15, 2019
    I got a picture of the back as well.
    What does it mean that a case is soft?
  9. X350 XJR Vintage Omega Aficionado Feb 15, 2019
    Soft would indicate the case is worn excessively and or polished.
  10. Foo2rama Keeps his worms in a ball instead of a can. Feb 15, 2019
    Soft means the edges are not sharp. Normally due to being polished. Some times excessive wear.
  11. Petervl Feb 15, 2019
    Looks like a 2505-29
  12. OMEGuy Feb 15, 2019
    Looks like your avatar...
  13. Petervl Feb 15, 2019
    Yes :)
  14. Petervl Feb 15, 2019
    Got to change it now :)
  15. OMEGuy Feb 15, 2019
    This watch is different from the OP's watch, obviously.
    Don't know what you are intending, but helping the clueless would be an option to think about.
  16. Petervl Feb 15, 2019
    2505-30 new Avatar :)
    Biezmez and OMEGuy like this.
  17. OMEGuy Feb 15, 2019
    Come on. This thread is all about someone wants to know what watch this is he has there and you know it but you don't provide straight information?
    Instead of changing your avatar you should have added a closeup picture of your 2505-29.
    Walrus likes this.
  18. Petervl Feb 15, 2019
  19. OMEGuy Feb 15, 2019
  20. jeppehh Feb 15, 2019
    That you all for the help!!
    And what a stunning watch Petervl! Thanks for the pictures.
    I decided to pull the trigger and purchase the watch. Hopefully it will come a bit closer to the condition of your watch Petervl after a service. No movement pictures were provided, so fingers crossed!
    Will post pictures once it is in my possession and after it has been serviced.
    Biezmez, OMEGuy and Petervl like this.
