I'm a newish Omega owner so don't know a lot. I am fancying either a moonwatch (speedy) or a planet Ocean, one of my critea being comfortable to wear. At the moment I have a seamaster which is very comfy, so my new watch needs to be as comfy as this. I would like a large ish diameter with a thin ish case. Can anyone make any suggestions or provide information? Thanks
Hi Gasman, While I believe your question is meant well, you have to consider that the criteria of "being comfortable to wear" is in any case subjective. I suggest you look at the Omega you desire, and find the specifications on the dimensions - this is always accessible through Omega's own webpage, or a simple search on the dimensions of a reference via search engines. However, I would urge you to go try and wear the watch in order to determine whether you find it comfortable to wear. Good luck with it.
Thin case and Planet Ocean are 4 words that do not belong in the same sentence, unless "does not have a" is between them. I've got the thinnest generation of PO and it's a thick watch.
