  1. gogo000 Feb 10, 2017
    Gents, I am ready to buy but needs your help and blessing. Thank you in advance.https://www.ebay.com/itm/132090314554Purchases made through these links may earn this site a commission from the eBay Partner Network
    BurntAvocado likes this.
  2. efauser I ♥ karma!!! Feb 10, 2017
    Recommended Vintage Omega Watches On Ebay (not Inquiries)
  3. Jwit Not a doctor, but plays one on ΩF Feb 10, 2017
    @gogo000 I'm going to give you a little hint. People aren't going to just give you a free assessment of a watch you post from eBay. If you take some time and research the model and what it is supposed to look like(using references like Omega or other posts on this forum) you will be able to form your own opinion on the authenticity and condition of the watch. Once you do this share what you have found and members will be more willing to chime in with their thoughts/assessments
    -Jake
    gemini4, marco and oddboy like this.
  4. CanberraOmega Rabbitohs and Whisky Supporter Feb 10, 2017
    As requested
    efauser, Deafboy, marcn and 2 others like this.
  5. gogo000 Feb 10, 2017
    Thanks. Being a rookie on this forum I obviously need to learn. In my defense I did read a lot of particular models, calibers, authenticity but I am naturally very week to make a decision by myself. I had Omega Geneve 1966 (gift from father) and it was stolen from myself 25 years ago. I always wanted to buy the one but was not in position to do so. Since a year ago I am in position to buy one with limited budget. Preference is the same year(1966) or better saying 66-69. Ref 166-041 introduced in 1968. Also my first choice is cal. 565 due to superb reviews. My original watch was manual wind and I could only assume it was 601 or variation but not sure. I was not in watches at that time. Thanks for your advise.
  6. Foo2rama Keeps his worms in a ball instead of a can. Feb 10, 2017
    After your research what are your concerns or specific questions.
  7. gogo000 Feb 10, 2017
    Thanks for help.
    1. I make a decision to only buy caliber from third generation. Should I worry or avoid any caliber from third generation due to whatever reason
    2. I can't recognize original hands. Should I worry about that and how to recognize them.
    3. I understood crown is easy to find
    4. Similar with glass
    5. Case is little tricky as I can't connect particular cases with particular model year or even type. I assume if case is stamped properly it would be OK.
    6. I am also not very good in recognizing repainted dials if not specified.
    7. I didn't even start research on bracelets, lugs.
    I fully understand if I continue reading I'll eventually get better on above questions but I I am not even close to that.
    If I learn everything by reading I might not buy the watch for another considerable period of time.
    Again thanks for asking.
    Foo2rama likes this.
  8. Foo2rama Keeps his worms in a ball instead of a can. Feb 11, 2017
    Best thing to do is google that reference which is on the inside of the caseback. Check for similar watches to see if the hands and dial are correct. There is likely to be many variations of the watch.
    The hands do appear for the right length and I see no obvious sign of a redial.
    Check to make sure the movement is correct and the serial number make sense for the year range also easy via a google search of the reference.
    The case lugs look reasonably sharp so it's not polished past losing value.
    The strap is most likely after market which would be expected. Most likely the buckle is also not original, which is not a huge issue.
    Look at past eBay sales with above knowledge to figure price.
  9. gogo000 Feb 11, 2017
    @Foo2rama,
    Highly appreciated for you input. Thanks.
  10. Foo2rama Keeps his worms in a ball instead of a can. Feb 11, 2017
    FYI it is a 34mm watch. 36-38 is what most male collectors are going after.
  11. Deafboy His Holiness Puer Surdus Feb 11, 2017
    I guess I'm an exception to those male collectors.;)
    I would like to point out to our newest members is that most dress watches pre-1975 are smaller than 35 mm.
    Edited Feb 11, 2017
    X350 XJR and Foo2rama like this.
  12. ConElPueblo Feb 11, 2017
    ::confused2::
    Vicke likes this.
  13. Foo2rama Keeps his worms in a ball instead of a can. Feb 11, 2017
    i blame booze
    Jwit, Deafboy and ConElPueblo like this.
  14. Peemacgee Purrrr-veyor of luxury cat box loungers Feb 11, 2017
    Male - check
    Collector- check
    Majority of Watches under 35mm - check
    Finding booze in Kuwait - about as difficult as finding vintage Omega dress watches 36-38mm
    Enjoy your booze @Foo2rama !
  15. gogo000 Feb 15, 2017
    Geneve from fifties are exceptional. What do you think if this correctly priced.https://www.ebay.com/itm/381552165455Purchases made through these links may earn this site a commission from the eBay Partner Network
  16. shaun hk Fairy nuffer Feb 16, 2017
    In my opinion that is a lot of money for a dial in that condition
    efauser and ConElPueblo like this.
  17. ConElPueblo Feb 16, 2017
    With Geneves of this sort two things are paramount - case condition and dial condition. In my opinion it'll need to be good in both regards to be really attractive. I'd love a decent example of one.
    EDIT: re. price - I don't think that this one is too badly priced, but it does require some attention, both cosmetic work and a service. Still, with a well-worn dial like this, it'll never be really attractive.
    Deafboy likes this.
  18. gogo000 Feb 16, 2017
    Conelpueblo,
    Well said. Thanks.
  19. gogo000 Feb 18, 2017
