I have been searching for this information in google. I am on a mission to find bar bracelet for my Speedmaster TV dial 176.0014 which currently does not have the bar bracelet. Originally the bar bracelet from 176.0014 is 1204/212. I recently found a seller who is willing to sell the bar bracelets from his Speedmaster 125 which has similar type of bar bracelets. However, his one came with number 3033/213 - new purchase (originally 1221/212). Can anyone please help me out if the 3033/213 can fit to Speedmaster TV Dial 176.0014? Thank you in advance for any inputs given. Josh
I used and extension of my 125 anniversary to extend the bar bracelet of the Mark V = same at least for this bracelet part .
Hi Fatcat, Thank you for you reply. Seems like, the bar bracelet is the same but perhaps it need an extension. The extension that you meant is the link that links to the watch case. Is that correct?
Got it. Pretty much the bar bracelets are the same just the width needs to be adjusted (bigger or smaller) by using the extension link. I hope I get this correct.
I used to own a 176.0014 with the bar bracelet. I don't think any of the 125 bracelets will work, simply because the final link (that attaches to the case) is significantly wider. I think that what Fatcat means is that the removable links (those closer to the clasp) are the same for both bracelets. Have you tried Omega ? Back in 2006 they restored mine and they did have extension links and screws for mounting to the case in stock. Maybe they do have the bracelet in stock too.
