Hi guys Do somebody of you know what kind of Lemania movement is in this watch? This watch has a 7 hands 1. Running second (left register) 2. Hour hand 3. Minute hand 4. Second hand (chrono) 5. Minute hand (chrono) 6. Hour hand (chrono) 7.??? I haven’t seen this before. Thanks Adri
@Adri, Flat out guessing its an automatic Lemania 134x, 5012 or 5100. Only way to know for sure is to take the back off, whilst you're taking a picture of the movement it would also be interesting to get and inside case back photo. I am seeing two watches in one along with parts I've never seen before on any Lemania.(please note I am not an expert, just a dedicated fan). Does the watch run? How do you set the gmt/#7 hand?. However I am going to be a little critical of this particular creation. 1) There are know references of the Lemania branded version of the omega "soccer"/football timers. Neither have the green inner bezel(I have seen Orange and Tachy). Neither have hand #7. The #3 minute hand is in same format as an Omega with needle tip but Lemania has pointy tip like on the hour hand. 2) There are also known references of the GMT function implemented with hand #7. This time the watch seem close to the Sinn 140/141 3) The oddities, I've not seen inner bezel in green before. Nor have I seen "automatic" directly below "Lemania" at 12 Hope this helps, All the best Pat
Hi. @tapaptpat nailed it. This is a GMT version of the movement as used by Sinn. Never seen a Lemania badged one before. http://www.sometimeago.com/what-a-watch-sinn-140/ Please share some movement pictures. Cheers
