I think this is your watch - and also in pink gold... I am pretty confident about this given the size of your watch...
It houses the smaller cal. 361 opposed to the larger Cal. 30 T2 which was used in similar case design.
Here is the similar OT 23
72 which has a 30 T2 SC (center second) inside
Should your watch house a 30 T2 instead of cal. 361 this would be a different story then and most probably a different ref.
You will have to have it opened by your watchmaker for exact determination - take photos of the movement and the inner case back then and show them here.
hope this helps
