Help needed finding a better dial for my old Omega Seamaster. I have been keeping an eye on eBay for sometime, but with no luck. Hoping someone can point me in a better direction, without having to send to Omega or having the dial refinished. There are two dial variations, one with “Chronometer” script, and one without. Either would be fine for me. Specifications: Omega referance 168.0061/167.0172 Omega caliber 1011/1012 Dial diameter is 27.5mm First pictures are of the current dial, and last is what a mint one looks likes. Thanks and hope to hear from someone soon!!!
Is your movement a 1011 or a 1012? I’m assuming it’s a 1012 in which case you should not have the chronometer wording on the dial. Not sure about sourcing besides eBay. Could also try a donor watch if you can’t find a dial alone.
Movement that is in there currently is a 1011 (it’s a donor movement, with the original dial). It’s a sentimental piece, so either dial is variant is okay
Seems like 168.010 / 168.024 Seamaster (caliber 565/564) also has a 27.5mm dial, so wonder if the caliber 1011/1012 dials would fit the 500 series movement? (same date window location, same dial feet location)
