what dial measurements do you need? If you just need diameter than you might be be able to pop the bezel/crystal off the front and take direct measurements without messing with the movement. If you need the dial feet, that is WAYYYYYYYYYYY more involved. In order to pull the movement there are a few screws minimum holding it in place. Sometimes there is a ring. It really depends on the particular watch. I don't mess with my chronos, but I know with time only there both button release and screw release for the stem/crown. Sometimes even the same caliber will have both types depending on what generation it is. Push buttons will have a little dimple in the middle, screws will be obvious, so should be easy to tell which type. Once released it should just pull straight out.
At that point the entire movement/dial package should come out in one piece. Then you would have to pull all the hands, using the proper tools and a dial matt, then you would need to release the screws clamping down the dial feet, and THEN you could remove the dial to check the dial feet measurements. You would then have to do the opposite to re-assemble. Use finger cots and don't touch anything with your bare fingers.
Again, I have NEVER worked on any of my chronos and would not recommend you try this!!
It takes special tools, it's very easy to strip the screw heads, damage the dial and hands, etc.
If you really want to mess around with something, try a throw away time only that doesn't matter if you screw it up.
anyhow, my 2 cents...
