help reading and identifying case back on sea master 168.022 67
Hello everybody just need some advice on what these letters mean on the back of this case back mean? is this the serial number? (B 6925)
will attach photos
Photos of front and sides and movement will help
168.022 is reference number for Chronometer grade Seamaster
564 on the movement is the caliber number for the chronometer grade movement
18k .750 on Caseback indicates 18k solid gold case.
If you move the rotor on the movement a but you will find a serial number which will allow you to date the movement.
The B6925 inside the Caseback is carmaker’s number for the case
This is a very nice chronometer grade seamaster with 18k gold case in very good condition
Do you own the watch?
Edit- the serial number may be just above the cal 564 but appears to be blurred out on photo.
I do not own this, but just looking at a few options and stumbled across so I was curious but thank you for your response and keeping me educated!
If you’re thinking of buying it make another post asking if dial is original. I think it’s ok but this can be tricky call so post the question before buying
