I've never seen that hand on a Dynamic & the condition of the watch and bracelet isn't good. The second hand is from somewhere else, probably from a make do and mend repair. Due to the poor condition of the dial the watch isn't worth a lot - probably £200-300.
That said, the movement used in this version is strong & if it is properly serviced could give many more years of use. Assuming the movement hasn't been abused and ruined in the past, that is.
You could make this into a decent watch to wear by replacing the crystal & bracelet, for approx £100 plus labour. If you want to spend more then you can have the case refinished for £100-150 & even replace the dial - but at that point it really starts to be a different watch & the renovation will be costing nearly the same as buying a good original.
Hope that helps.
