Hi All, I have a 2594.50 Seamaster Chrono America's Cup with the original bracelet. I'm looking to purchase a rubber strap or the leather-like rubber strap and want to know what straps will fit properly. Will either or both of these straps work with my watch? Where is the best place to get either or both of them? Thank you so much in advance, in the information age today, I can't believe information this simple is so hard to find. Omega Black Rubber Deployment Band 20 mm 98000037 (Which deployment band would you suggest?) Omega Black Rubber Strap 98000085, 20 mm Long John
Looked up the reference, and then looked at the case number, and then searched on the straps that go with that case. So according to the Omega Extranet the following strap is for the case: 98000085 - RUBBER DIVER BLACK 20X20 INT XL And this tang buckle goes with that strap: 94512012 - STEEL BUCKLE (SAT.) TONGUE 10 - 20MM Cheers, Al
