Help Omega 105.003-65 4:00 Pusher Does Not Return Second Hand When Pushed
I hope you can help. This watch has just been restored for around $2k in the past 2 weeks. I am told that either the part of the pusher that goes into the movement is stuck or it has become stuck in the movement ring. Is it possible to explain to a novice what this means? Would one expect the repair to be under warranty?
If the watch was recently repaired/serviced, I recommend taking it back to the watchmaker and asking them to fix it.
Would you expect the fix to be under warranty?
Of course. It it needs a new part that was missed during service you may be charged for that unless parts were included in the service cost.
My feeling is that after spending $2k for a restoration, one would expect the watch to work properly two weeks later. They should absolutely fix it.
I would certainly not be happy with the service provider if it wasn't fixed under warranty!
I had the same issue with an 105.03-64 that had just come back from a full restoration.
Called the company and they had sorted it within a week
