Did you synch the hands to the digital time following the instructions in the manual? I believe this has to be done every time the battery is swapped. The AD’s watchmaker may not have done that. If you did the procedure to synch and it is still off, it does sound like a faulty module and will need work by Omega. I expect they will honor the warranty since this is a quartz watch, and from a quick perusal of the web, a common fault on these watches.
