Greetings, Omeganuts. I've been trying to track down a beads of rice bracelet that will fit a 1960s-era one-piece-case Seamaster Deville -- the kind with the faceted lugs that angle down. The bracelets I currently own are all made for the "beefy lug" Seamasters, and thus are curved to fit the profile of the lugs -- these don't match the "straight" profile of the Devilles. My question: Does anyone know the reference numbers of the bracelet that will fit a Deville? So far, my research has revealed that it "might" be a 1037, and that the proper reference for the end links is 570. Am I one the right track? Thanks, guys!
I don't know the numbers, but I believe you need the version that has 7 rows of rice beads with the flat outside rows on either side, not the older 5 rows of rice beads.
It would definitely depend on the case ref. number. You can find the case reference numbers on which the 1037/570 combo was attached here: http://www.ofrei.com/page1281.html Just search "1037" on the page, and you'll get all the info you need. Good luck
