Help identifying year/model of speedmaster
Hello and thank you for your input. My Uncle gave me his father's speedmaster he received after watching the Apollo 12 launch. It should have been in late 1969 or 1970 when he received the watch. It was worn very little and spent most of its life in its box (paperwork has been misplaced) but I still have the box with the moon surface artwork. I winded it and everything appears to work and was wondering if the community could help me with identifying it.
Hi.
145.022-69 with 220 error bezel is my guess.
One of the nicest examples I have seen too.
Cheers, Michael
Stunning watch - the last picture shows the 1039 bracelet has a production date of Q3 1970.
Hi.
Cheers, Michael
Thank you very much for the help.
A few questions, and I know everyone has different opinions:
Is this something I should or need to get serviced?
Is this version something criminal to be wearing and it should stay in its box? I am not well educated in the watch world and any advice would be greatly appreciated.
The fanciest watch I have owned to date is an Orient Kamasu so this is quite an "upgrade".
Very nice heirloom. If you are going to use it, the watch should definitely be serviced. Whether or not to wear it is your choice. I would, but it depends on your risk tolerance. Due in part to the fine condition, the value is in the range of $10k USD including the bracelet IMO.
Hi.
Cheers, Michael
This is spot on and the 1039 bracelet is quite valuable. This is a very nice example. Check out https://speedmaster101.com/
Also, best not to run it until it has had a proper service. The oils will have all dried up. If you let us know your general location we can recommend a good watchmaker in your area.
I concur. Watch, bracelet, and box make a very good package.
I really appreciate the feedback. I would like to see about getting it serviced whether I wear it or not. I live in Asheville, North Carolina so if you have a recommendation on servicing that would be great.
If you are not going to wear it there’s really no reason to have it serviced since it would need to be serviced again in 5-10 years. And anytime the watch is worked on there is some risk.
I found a few relevant threads:
https://omegaforums.net/threads/recommendations-for-a-watchmaker.129513/page-2
https://omegaforums.net/threads/vintage-omega-watch-repair-in-raleigh-nc.62116/
You can also consider shipping your watch to a watchmaker as I and many others here do.
I overlooked this question before.
This watch is a much better than average example of a not so rare, but desirable watch. It is a family watch so that makes it extra special for you. I inherited the same model of watch as yours from my father and wear it regularly. However the condition of mine is not nearly as good as yours, and I would value it at less than half that of yours. The main issues was that the dial was replaced with one from the 1990s, and the bracelet is a different model from the late 70s. The caseback is engraved with my dad's name and the date he earned his masters degree (it was a gift).
I do wear mine quite regularly, but I am careful. Water is my number one concern, followed by impacts. There are many threads about water resistance of Speedmasters (e.g, https://omegaforums.net/threads/anyone-go-swimming-with-a-speedmaster.47840/ ). When new it was water resistant to 50m, and if properly serviced it might be able to get back to that level. However, I see no advantage to getting it wet. I will wear mine on a drizzly day under my sleeve, but not in a rainstorm or swimming. I am also careful using a hose because the water is under pressure. I avoid hammering, drumming, and other activities involving excessive force.
Even if you are careful the watch will acquire extra scratches and dings over time. This will affect the value to some degree, but what is a watch for if not to wear it? Nobody here would think you were a fool if you wore the watch, but some might think you were a fool to keep it locked up in a safety deposit box never to be enjoyed.
One thing that hasn’t been mentioned: the “crystal” over the dial is actually a piece of plastic, that can be very easily buffed by you using just a little care and a very cheap product called polywatch ($2?)
I won’t recount here the detail, but mentioned it because: with polywatch and 2-6 minutes of elbow grease the crystal on that watch should lose most or all scratches and better reveal the dial.
Just be careful to not accidentally buff any metal, watch a YouTube video or two, and enjoy the quick and cheap facelift!
