I'm pretty sure I would like my incoming sword hands diver to look like this. Can you help identify the strap and clasp shown here?
Ofrei: http://www.ofrei.com/page750.html Omega Deployment Clasp for Selected Rubber Straps 9453-1803 Special deployments clasps for certain Rubber Straps. Clasp OMEGA 117ST1506832 (discontinued) is interchangable with clasp Omega 94531803. OME-94531803 $398.00 $320.00 Omega Black Sports Rubber Strap 20 mm This strap takes the special Omega Deployment Clasp 9453-1803. If you already have bracelet 1503/825, which is also found on case 168.1613 this rubber strap is interchangeable on the same case. If you have bracelets 1513/825, 1514/825, 1504/826 or 1610/930 you can also use this strap. This strap is found on model number 2834.50.91, while Model 2231.50.00 is issued with Titanium Bracelet 1610/930 and you can wear the OME-98000037 or OME-97996082 both are black rubber straps or the blue rubber strap OME-97988082 Omega does not offer this strap in a 18 mm version. Case number 168.1613 uses spring bar OME-SPRING-BAR-04. Will go one case 145.0022, however does not look right with visible gap between case lug and band. OME-97996082 $320.00 Omega Blue Sports Rubber Strap 20 mm This strap takes the special Omega Deployment Clasp 9453-1803 clasp. This strap can be found on case number 168.1613, 178.0514, 168.1503, 168.1603, 168.1623, 178.05.4, 196.1503 and can be found on many more 20 mm cases. If you already have bracelet 1503/825, which is also found on case 168.1613 this rubber strap interchangeable on the same case. Model number 2531.80.00 came with 1503/825 and can use this Omega Blue Sports Rubber Strap 20 mm OME-97988082. Model 2231.50.00 is issued with Titanium Bracelet 1610/930 and you can wear the OME-98000037 or OME-97996082 both are black rubber straps or the blue rubber strap OME-97988082. If you have bracelets 1513/825, 1514/825 1504/826 or 1610/930 you can also use this strap. Omega does not offer this strap in a 18 mm version. The buckle end is 3 11/16 inches, hole end 3 11/16 inches, and the entire band is 7 7/16 inches. OME-97988082 $320.00
Caution the 98000037 is a beautiful black rubber-like strap (stitched) but it is padded LEATHER. I ordered it for my 2254. It is NOT waterproof. NO WATER on this strap ever or you will lose a lot of money very quickly. This is NOT the stitched rubber strap for the Planet Ocean.
