The movement (mechanism) might be an Omega calibre 580. A very small diameter movement. Your images don’t show a lot for scale, but it appears to be a very tiny watch. The appraisal indicates the case (and likely bracelet) are 9 karat gold which would imply it was made possibly for the English market. The crystal in the watch appears to be the same style and content as the crystals used in the Omega Sapphette series of watches. That is, it is likely synthetic sapphire (not glass), and the facets around the perimeter have been applied by lapping, using the same method as faceting precious gems. As has been stated, the model number will be stamped inside the case back. There is both (likely) sentimental value and intrinsic value in the watch. I would suggest that if you (assuming you are female) or another female in your circle might appreciate this beautiful watch, then it has more than the value for gold scrap. If you sell it for scrap, it is likely the money will be gone in a week. If you appreciate what you have and keep it, you’ll have it for your lifetime, as will your heirs.
