I'm on my android phone,they apear attached when i want to edit or make new post they upload but they can't been seen. I don't know the reason i had problems in the past,because of android.
Click on "add photos". They will then appear as thumbnails below the reply box. Once they have uploaded, click on " insert" next to each or "insert all" above those thumbnails.
Thank you i can't post the print screen the insert button doesn't exist. There are only 3 option : Preview,add photos and reply.
If i wouldn't press that button how could i attached the images.... ? Thank you ! I attached other times so i know the procedure,something else is going wrong.
If you're missing the button for both "insert photo" and "insert all" then something is amiss. I've used it this morning so it's unlikely to be the site and more likely your browser. Close your browser (and anything else) then restart your phone and/or clear cache. That's probably where your problem lies.
Manage it,looks like the photos had some kind of protection,and that was the cause. View attachment 644630
20f movement from early '30s, export model that I believe may have been for the French market? (need a little help) Probably had blued steel kite hands, dial has at least been cleaned and may be an old redial. Please post a picture of the assembled watch and we should be able to give you a reference number and more info. I had a similar one that was lost(?) by the USPS.
Nice project! I love this caliber. I serviced it a couple of times. The anchor is original and has a nice design. Hard to tell, but I would say the dial is original. The watch was designed for the French market - you can read "importé de Suisse. It will be a great watch with the correct hands and after a service (always a good idea and I can already see that the second hands post is bent. Francois
