I have had this watch for about 4 years and still I am unsure of the correct reference. If I knew that I could search for a correct backcase which is obviously a replacement. Any help from the experts would be most appreciated. The movement serial number is 177xxxxx and as I said the caseback is most certainly incorrect. I very much look forward to the replies and thank you for any help given. Best regards Paul www.heuerworld.com
Thanks for all the replies so far. It has a screw back case and i think the lugs are different to the 105.001. Inside caseback and movement pics below but I am 99.9% sure the caseback is wrong. Looking forward to more replies. regards Paul www.heuerworld.com
The closest I've seen to your model is one with red gold hour markers and hands (ref. CK 14.364) with a screwed case back.
Looks like model 14364 and caseback is wrong - not just in model number but it is for a gold plated case and not a stainless steel one. Also unless it is a white balance issue the plating looks to have been stripped from the movement - should have a more copperish hue.
My guess 14364-61 Here's a pic and link to one on wannabuyawatch http://www.wannabuyawatch.com/indpages/39832.html
Thanks for all the input which end up confirming my suspicions that it is a reference 14364. Now if I can only find a case back. regards Paul www.heuerworld.com
