FS OMEGA MILITARY 1942 RAF issued; HS version;unmolested case!;works fine
Here is the rarer HS ( Hydrographic survey ) version of Omega`s WW2 Pilots watch. 1942. Alloy Middle unmolested with the very long lugs; not damaged or shortened ! some battle scars, but nothing serious. fixed bars. the upper of the brass fixed bars was missing. we replaced it with a stainless steel bar. secured with a drop of glue to avoid another mishap.... the lower bar is the original brass one; a bit worn now. secured as well. easy to remove, if desired. the lug holes are perfect. therefore the lugs are perfect. which is quite rare with this model; most have lug issues.... original "Bubble" glas with scratches. original crown. original case. original dial; not repainted. the script is very fine and original, but faded with age. has morphed into a silver colour with some age areas. shown in the pictures. . only the center has the light whitish colour . blued hands. the center second hand looks replaced with a different tail partand slightly thicker. works well, but service history unknown. therefore sold as is. HS engraved back has some pressure marks in the middle from opening and closing, i guess. movement looks very clean; a replacement of the mainspring might the way to go at the next service. diameter without crown: 33 mm. with crown: 35 mm. lug to lug: 43 mm. thickness: 12 mm. Paypal payment not possible here. bankwire or Transfer Wise for best rates and quick service. we only ship via Post courier international,EMS for A$ 65. the Covid related travel times from Down under are too unpredictable otherwise. somewhere there is the Bonklip band as well; have not found that one..... will let you know, if i do. we ship and declare in a way, that you do not have to pay all fees entering europe.....we offer full value insurance for 1% of the value, without showing on the parcel. via a 3. party insurer. Asking US$ 2400.
Found the Bonklip band ! Is included in the sale, as is free courier shipment and full value insurance as well. And a 4. Of July reduction to $ 2100. Stay safe !
