Although the two movements are the same in size, the 145.013 case for the 910 has different external dimensions.
The exact dimensions of each case are given in this old article by Chuck. It appears only the thickness differs between the cases (by 1mm). http://chronomaddox.com/flightmasterarticle.html I have absolutely no idea whether each case will accept either movement. I'm sure the flightmaster experts/owners can confirm (I'm just someone who dreams of acquiring one someday... ).
I highly doubt so. Different dimension, different case curving (910 is flatter) and I believe different mechanism on the 9 o'clock sub dial may affect,too.
Thanks for the input....seems like almost little chance to get just one of the 145.013.,, have checked the past 'Parts and accessories for sale' without luck Anyone have any leads?
Hi again, am trying to finish up fixing a complete 910, need help to check if the inner bezel of the 911 will be compatible with the 910? thank you guys!
